MP3 Player Help
10 replies to this topic
#1 funkGASM
  • 6 posts
Posted 11 April 2006 - 05:20 PM
Funkysoul, great tutorial. I have managed to get the flash player working just fine on all my mac browsers but when I check it on a PC in Firefox and IE I just get the "loading..." message. I used the code from the first tutorial so I figured it would work just fine. Also... your sample player just displays the "loading..." message. I have the most current flash plug-in installed. The player is here... http://staging.giffo...n.com/sweetlou/ Thanks for the help!
#2 travmanx
  • 25 posts
Posted 11 April 2006 - 09:13 PM
Works fine for me, make sure on your PC you have Flash 8 installed.
#3 funkysoul
    The Funky Stuff
  • Publishing Betazoids
  • 2,307 posts
Posted 12 April 2006 - 02:20 AM
not working for me either.. which is very strange..
and you say it runs on a mac, but not on a pc?
#4 funkGASM
  • 6 posts
Posted 12 April 2006 - 09:39 AM
Yeah it is working on my 2 macs, and funny thing, it works on one of my PCs now to. I did this in MX but I just got Flash 8 so I will try resaving it in that and see if that helps at all.
#5 funkGASM
  • 6 posts
Posted 12 April 2006 - 10:08 AM
Well it seems it made it worse, now on the mac it says loading then almost immediately after goes blank, the songs still play but I can't see the title and it appears the fw and rev are not working. The PC still hangs on loading...
Edited by funkGASM, 12 April 2006 - 10:10 AM.
#6 funkysoul
    The Funky Stuff
  • 2,307 posts
Posted 12 April 2006 - 10:20 AM
can you put the fla for download on your server? I will have a look at it.. also please include the html where it being published..
#7 funkGASM
  • 6 posts
Posted 12 April 2006 - 10:30 AM
http://staging.giffo...weetlou/mp3.zip
I did get everything working on the mac again. Thanks for helping!
#8 funkysoul
    The Funky Stuff
  • 2,307 posts
Posted 12 April 2006 - 04:37 PM
try this version:
http://www.six4rty.ch/p2l/radio.zip
#9 funkGASM
  • 6 posts
Posted 12 April 2006 - 04:55 PM
Thank you very much... I will send it to the band and see if they can hear music now. If they can't then I am going to have them send their OS info so I can research the issue further.
#10 funkysoul
    The Funky Stuff
  • 2,307 posts
Posted 13 April 2006 - 05:18 AM
yeh, let me know if it worked out.. this is a problem which I never could re-produce.
#11 funkGASM
  • 6 posts
Posted 13 April 2006 - 02:44 PM
Ok, sounds like it is working now for the band. They only couldn't see it on their work computers, same as me. Must be a firewall or OS thing or something, I have no idea... but BIG THANKS for all the help. I have never seen someone as dedicated to helping people as yourself, thanks again!
