c4d help plz
2 replies to this topic
#1 xS1cKx
  • 1 posts
Posted 29 December 2004 - 03:01 PM
ok i save my render in c4d.. is there anyway that when u open it in Photoshop for it to have a transparent bg????
#2 Centercore
  • 48 posts
Posted 29 December 2004 - 10:11 PM
when u are in render settings below where u can choose ur saving format tick alpha channel then save the render as a quicktime .png or if u want save as a targa then with photoshop goto your alpha channel and select the alpha layer with the magic wand go back to your layers and invert select it then dup the layer press delete then delete the background.
i didnt use much detail in this cause its been posted if you look back you can find it.
#3 Yieldy
  • 143 posts
Posted 01 January 2005 - 09:11 PM
what you do is, on the Save tab in Render Settings, select in the drop box where it says TIFF, select from that list TARGA and then near the bottom check the Alpha Channel box, then render in the Picture Viewer and then open in photoshop and it has a transparent BG.
Hope this helped!
