Help!
  • Please log in to reply
9 replies to this topic
#1 chelsea
chelsea
  • 41 posts
Posted 17 June 2007 - 08:12 AM
Ok I have CS3 [to install it I uninstalled CS2] and I need ImageReady only
how can I install ImageReady without installing Photoshop?
#2 Scythar
Scythar
    Honored X Staff
  • 1,888 posts
Posted 17 June 2007 - 12:14 PM
this is by far the strangest question i ever heart!
frankly i dont know ! :oops: sry.
#3 Dance
Dance
  • 871 posts
Posted 17 June 2007 - 12:27 PM
I don't think you can... I believe that you need to have PS installed to install IR. Many of the same components are used and IR is supposed to be a interface to PS that does somewhat more specialized tasks. But IR is still a part of PS even tough its a separate .exe
#4 chelsea
chelsea
  • 41 posts
Posted 17 June 2007 - 12:47 PM
I see.. Maybe you can answer me this:
How can I import the frames from an aninated Gif file?
#5 Dance
Dance
  • 871 posts
Posted 17 June 2007 - 12:52 PM
Open the gif in IR and they will show as separate layers. I dont think there where anything else to it then that but im not 100% sure on straight arm.
#6 chelsea
chelsea
  • 41 posts
Posted 17 June 2007 - 12:57 PM
Yes I know how to do it in IR but the problem is I don't have IR
installed [for that^ reason] that's why asked is there a different way :) ?
#7 SkyDiver
SkyDiver
  • 26 posts
Posted 17 June 2007 - 01:44 PM
lol I see...well if you want to have ImageReady you need install CS2 or an earlier version since IR is obsolete with the merging of Macromedia. Read here for more.
#8 chelsea
chelsea
  • 41 posts
Posted 17 June 2007 - 02:17 PM
So fireworks is like IR?
#9 SkyDiver
SkyDiver
  • 26 posts
Posted 20 June 2007 - 03:28 PM
Why not just use Dreamweaver since it's integrated for a seamless workflow between Photoshop in the CS3 version.
#10 Av-
Av-
    I Feel Left Out
  • 1,972 posts
Posted 22 June 2007 - 12:20 PM
Imageready is (finally) integrated into PS in CS3. Click the 'window' menu and check the 'animation' option. Once clicked, your precious IR animation window will appear :)
