Ok so one of my newest prjects requires a ball to bounce off of a wall, simple enough, however the wall can be at various angles.....ah.
My tallents have never been that of physics and although i grasp the basic concept of such collisions and calculations, i seem to repeatedly fail when attempting to work round it all in flash.
as you will see by the example bellow (give it a few bounces, move the wall about a bit untill you see what i mean) it works sometimes but often gives unusla collisions, like the ball going off at completly unrealistic angles.
So, heres an example of whats going on at the moment: [link]
Heres the code i am using for the project: [link]
and here is my plea for anybody who can help me, be it correcting the code im using, or even sugesting a completely new route to take with it, im all ears.
The problem, is basic Physics
Started by
flamereaper
, Jul 14 2008 07:35 PM
1 reply to this topic
Posted 14 July 2008 - 07:35 PM
Posted 28 September 2008 - 01:28 PM
I have the same exact problem for a marble maze game. Forgive me, I couldn't find your code anywhere so I went ahead and decompiled it.
In your function collide, you have:
ball._x = ball._x + newXVel; // capital "V", there is no such variable newXVel, did you mean newXvel
This is some pretty cool code, though I can't seem to get it to work for my game. In particular, when the ball hits a corner of a wall, all hell breaks loose.
Does anyone know any good tutorials out there on resulting movement of a ball AFTER a collision? I can find tons on collision detection, but none on what to do after a collision. Thanks.
function collide(){ wallAngle = angle; ballAngle = getPosAng(Math.atan2(-ball.yVel, ball.xVel) / 1.745329E-002); norm = wallAngle - 90; diff = getPosAng(norm - ballAngle) - 180; reflectAngle = getPosAng(norm + diff - 90); arr2._rotation = reflectAngle; impactVelocity = Math.sqrt(ball.yVel * ball.yVel + ball.xVel * ball.xVel); newXvel = Math.sin(reflectAngle * 1.745329E-002) * impactVelocity; newYvel = Math.cos(reflectAngle * 1.745329E-002) * impactVelocity * -1; ball._x = ball._x + newXVel; ball._y = ball._y + newYvel; ball.xVel = newXvel; ball.yVel = newYvel; trace ("impact velocity: " + impactVelocity + "\t Normal Diff: " + diff + "\t reflect: " + reflectAngle + "\t new x: " + Math.round(newXvel) + "\t new y: " + Math.round(newYvel));} // End of the function
