Brief description of what i'm trying to do:
I have an animation of someone moving accross my stage following a path.
I need to mask this animation but can't apply a mask to something following a guide path and vice versa.
All I can find tutorial-wise is how to make a mask follow a path, i've been looking for a while. it's my first time in flash and i'm not using actionscript, just tweening.
can anyone help me?
Combinging Masking and Guided Motion Tweening?
Started by
JamesCharlick
, Aug 21 2008 10:31 AM
1 reply to this topic
Posted 21 August 2008 - 10:31 AM
Posted 05 September 2008 - 11:20 PM
once you know the tween is the way you want, you could select all the tween frames, convert them to keyframes, and remove the tween. this effectively turns your tween into a fram by frame animation which wont rely on the motion guide, so you can then get rid of the motion guide layer, and apply your mask to the animation.
