Color Problem
13 replies to this topic
#1 arsonist
  • 4 posts
Posted 22 July 2005 - 04:38 AM
Well I've had a problem in photoshop since yesturday, i've looked around i cant figure out how to get the colors back to the default RGB (how they are origonally)
I took a screen shot of what the color tool looks like at the moment:
Help?
#2 hasouni
  • 29 posts
  • Interests:Soccer, Sports, Computer, clubing etc
Posted 22 July 2005 - 04:47 AM
heheheh i had tht when i started with photoshop and then i fully re-installed it becouse of it HAH!, ok well what you do is
See where you see the dot buttons ( H..S..B R..G..B etc)
Well click H or just click between them and it will be fixed :)
#3 arsonist
  • 4 posts
Posted 22 July 2005 - 04:49 AM
LMFAO...wth...
All i had to do was click that.
Well thanks so much for your help man, i appreciate it, i probably would have re-installed too =P
#4 hasouni
  • 29 posts
Posted 22 July 2005 - 04:51 AM
:) np mate.
#5 InFnit
  • 822 posts
  • Interests:My interests are my:<br><br>iidsite - http://iid.outer-heaven.net<br>iidblog - http://iid.outer-heaven.net/blog/<br>iidcommunity - http://iid.outer-heaven.net/forums/<br>P2L - http://www.pixel2life.com
Posted 22 July 2005 - 06:01 AM
Guys this is a perfect example of what should be in the mini-paedia....(will put link in sig)
#6 hasouni
  • 29 posts
Posted 22 July 2005 - 06:48 AM
Sorry whats this mini-paedia? :D
#7 adam123
  • 2,306 posts
  • Interests:Programming and stuff.
Posted 22 July 2005 - 07:40 AM
Keep the shameless plugs to your own topics :D
#8 llE-Klipsell
  • 28 posts
Posted 24 July 2005 - 11:20 AM
I have the same problem that you man.when it first happend i just thought its was something i can fix by unstall nd restalling but its wasn't ever time i un-restall its still remain the same. well these what its give me. :lol:
this what pop up when i first open PS~~>
:D
and then, for the color~>
I try what ya say about clicking the H button, but its still remain green not normal ass image ready.
can yall help me with this B)
thanks ..
#9 Hacker-X
  • 174 posts
Posted 24 July 2005 - 06:16 PM
the scratch disk error is probably a warning to clear some RAM and some memory, but it may also be an indication of a virus infection, if it is a virus i'd just reformat becuase reinstalling photoshop wont work
#10 llE-Klipsell
  • 28 posts
Posted 24 July 2005 - 07:37 PM
how do you do that?.
#11 Jaymz
Posted 24 July 2005 - 09:04 PM
Actually it means exactly what it says, if you only have one hard drive they're fine set to the same (you can change it in preferences) if you have more than one, setting the secondary scratch disc to the second hard drive will boost performance.
The colors, check the color settings in the preferences, I'm sure there's some setting in there (I don't have PS open right now) :)
#12 llE-Klipsell
  • 28 posts
Posted 25 July 2005 - 09:13 AM
ok i found the Plugs-ins and scatch disk in the options..
But what do where it sed scratch disk
its say .. First-startup,second-none,third-none, and fourth none..
what do i do in there to reconfigure it ... ;)
Edited by llE-Klipsell, 25 July 2005 - 09:15 AM.
#13 Jaymz
Posted 25 July 2005 - 11:03 AM
If you have a second hard drive, set the second to the second drive, otherwise leave it ;)
#14 llE-Klipsell
  • 28 posts
Posted 25 July 2005 - 11:55 AM
i don't have a second hard drive.
