IPB Skinning - Removing the small white arrow on main headers!
Ever wanted to know how to remove the little white arrow on the main header.. everywhere on the forum? Instead of editing each little bit of HTML... Well there is a way!
<-- White arrow, if you don't know what I mean.
Well, simply:
1. Open up your ACP.
2. Go to,
1. Look & Feel
2. Press the drop down menu next to the skin you want to remove the arrow on
3. Select: "
Edit Replacement Macros"
4. Look for:
<{CAT_IMG}>
5. Press
Change
6. Remove everything in the "Replacement" area.
7. Press "
Edit This Macro"
Your done
Its as simple as that! No more hunting through looking for arrows to remove.
Hope this helps!
