Posted on March 14th, 2012
1458 views Share video or promote a product using video, It usually makes you worry because everyone can take your video without your permission. Now, you can use this software to add a watermark. We will show you how to make it easily.
Step 1 You can start adding Watermark by downloading the trial version from here Step 2 Run Flash Video Studio. Step 3 From menu, click on "Browse" button to open your video file. Step 4 Go to tab 3 "Overlay" to add watermark. You can add image and text watermark. To select an image watermark, first check the Have Image Watermark checkbox. Click the Browse button inside the Image Watermark control group to select an image file. By default, the image watermark position is set to the upper left. You can change it by selecting the watermark position from the Position listbox. Selecting the Custom settings position will enable you to type in the x,y coordinate manually. To select a text watermark, check the Have Text Watermark checkbox. You can then type in the text and adjust text standard parameter such as bold/italic/underline, color, text alignment, etc. Step 5 You can add the other settings too. If you have done, click on tab 7 "Publish", you can change the output, navigation, etc. Click on "Publish" button to create the output file. Step 6 Congratulation! Your watermark video is done. You can upload the HTML, SWF and flv files into your website.
Here is the result: Click here to see the flash video. |
