Posted on March 22nd, 2012
3758 views Assembly process presentation will look good when presented in animation. Today we'll show you a simple wayto make an animation about bicycle assembling process.
Step 1 Install and Run Flash Demo Builder from here Step 2 From the Startup menu, choose Blank Project, and set the dimension to 800 x 600 Step 3 From the bar menu, click Insert > Image, and choose beach.jpg as background project. Set the transparencyto about a quarter Step 4 Insert bicycle_direction.jpg into the preview window as a directive in assembling process and set the transparency toabout 25%as shown below: Step 5 Insert the following image in a series:bicycle_wheel.png,bicycle_fork.png,bicycle_wheel.png,bicycle_saddle.png,bicycle_frame.png,bicycle_klep.png,bicycle_steer.png,bicycle_frontbrake.png,bicycle_rearbrake.png, bicycle_gear.png Step 6 Adjust all images above to fit bicycle_direction.jpg as shown at step 4. Step 7 For bicycle_wheel.png, bicycle_fork.png, bicycle_wheel.png, bicycle_saddle.png, bicycle_frame.png, bicycle_handlebars.png,bicycle_gear.png, apply Pan/Zoom/Rotate effect. Congratulation you have done the bicycle assembly tutorial
Click here to play the flash file
