Posted on March 27th, 2012
1838 views Following are the steps how to make a simple and rapid slideshow for celebrating fruits and vegetables market .
Step 1 Install and Run Flash Incrediflash XTreme from here Step 2 Under Startup window choose Blank Project and set the dimesnion to 500 x 375 pixels. Step 3 Under Tools menu window, choose "Insert Image" to insert market01.jpg into the scene. Step 4 Click the "+" sign at the top of scene window to add 4 more scenes. Step 5 Insert the following images for the new scenes as you did at step 3,market02.jpg,market03.jpg,market04.jpg,market05.jpg,market06.jpg Step 6 Click scene 1 and under its Effect property window, assign Mask-Chekered effect under "Show after" setting and set theduration to 2 seconds. While for "Hide after" setting set the effect to Wheel-1 Spoke and its duration to 2 seconds as shownbelow. Step 7 Repeat step 6 for the rest of the scenes. Step 8 You can beautify the slideshow by adding transition effect for each slide as shown below We chose Curved Star Out 2 Pass transition in this lesson. Step 9 Congratulation! You have just made a slide show for celebrating fruits and vegetables market.
Click here to play the flash file
