Posted on May 2nd, 2012
1799 views In this guide, you will learn the simple steps in making a simple "Godfather" like design in Adobe Photoshop perfect for posters or print flyers. The steps are pretty simple, so even a beginner should be able to easily handle it. So do not worry about needing the right skills. Just follow the items and steps listed below and you should not get lost. So let us get started.
2. Next, we simply copy the area we selected and pasted it back as its own layer. To make it look better though, we adjusted brightness and contrast. Just go to Image -> Brightness -> Contrast and just adjust the dials until the image looks well toned. 3. Adjustments -> Curves and then adjust the curve graph a little bit like what you see below. It does not have to be exactly like the curve, just make sure that you see the details of our image better. This will vary of course depending on what kind of image you are working with. 4. Finally, before we actually create the poster document, we blur our image just a bit. This should help hide some of the imperfections in our cut, while at the same time smoothing out the overall shape. Just go to filter -> blur -> Surface Blur. Use a 3 value for the radius and a 6 value for the threshold. 5. Great! Now, we will create our poster document. Just press CTRL+N to create a new document. Set your dimensions to the correct poster size that you want. Also use a high resolution value that is appropriate for printing. Here we are creating an 11x17 inch poster at 300ppi resolution. 6. Once open, we set the background to black and then paste in our model. Here we scaled it up a bit by pressing CTRL+T and then transforming it to scale (hold down the SHIFT key). We also positioned it a bit off center with the feet hidden as we are going to be placing in some design elements around our figure of course. 7. Now, looking at our image, the darks are not dark enough for our effect. So with the pasted layer selected we go to Image -> Adjustments -> Selective Color |
