Posted on July 19th, 2012
2505 views Today we'd like to show you how to concantenate 2 distinct slideshow files by connecting them via http protocol.The lesson will take the example files within IncrediFlash Xtreme installation folder.
Step 1 Download and Run IncrediFlash XTreme program from here Step 2 Under Startup window choose "Open an existing project from your hard drive", click on the Browese button andfind Photo Slideshow.ifl under IncrediFlash XTreme installation folder. Step 3 Click on Publish menu bar and choose "Flash and HTML File" and click on OK button under Making HTML Files window. Step 4 Open the second file by clicking on the "Create a new project" toolbar, then choose "Open an existing project fromyour hard drive" to find Photo Slideshow Showcase.ifl under IncrediFlash XTreme installation folder. Step 5 Under Settings tab menu, choose "Open an URL" next to "At movie end" label. Step 6 You should put the files IncrediFlash Xtreme generated from those 2 project file into your web server in order tosee how they work.
Here is the result: |
