Posted on August 8th, 2012
1953 views Making carousel slideshows is not as complicated as common people imagine at the first time they see them. We'll show you how to make a carousel slideshow in short. You don't even have to have any prior knowledge about Adobe Flash or anything that has to do with programming.
Step 1 Install and Run InAlbum from here Step 2 InAlbum will show you a startup menu, choose "SHOW" button, then click "Create Project" button. Fill in the "Show name". For this tutorial, we use a Theme template from InAlbum. Step 3 Under "Select photo" window click on "add photos" button to start inserting your photos into InAlbum Step 4 Jump to "change Template" menu (step 3) and within Carousel category choose "Scatter" template. Step 5 Under "decorate Show" menu you can decorate your photo show with text and all available cliparts there. However in this lesson we don't talk much about decorating your show Step 6 After having all slides decorated, you can add background music to your show as shown in the "music & settings" menu (step 5). Or you can let the original template music intact. Step 7 Congratulation!, you have made your own carousel slideshow. |
