Posted on August 17th, 2012
3046 views Today we will show you how to make an e-card easily.
Step 1 You can install InAlbum by downloading the trial version from here Step 2 Run InAlbum Step 3 From menu, click on "E-Card" button. Then click "Create Project" button. Fill in the "Show name" and the folder location. Click on "OK" button to continue. InAlbum will let you to choose the template. For this tutorial, we choose "Family". Step 3 To change the photo, click on a photo and replace it with your own. Theother way, you can click on the object dropdown and choose "Photo". For this tutorial, we use the default. To change the text, you can clickon a text and retype your own text over it. It is as simple as that. If you wish you can add more photos, text and cliparts. Step 4 Once you are done, click on the Music and Settings to customize furtherby selecting thumbnail and music then click the Save Show button. Step 5 Congratulation!, your E-Card is done.
