Posted on August 17th, 2012
4309 views This time we'd like to show you a simple animation of spotlight effect.
Step 1 Install and Run Incrediflash Xtreme from here Step 2 Under Startup window choose Blank Project and set the dimension to 500 x 400 afterwards. Step 3 Set the background of the project file to Gradient with Horizontal type as shown below set the RGB value for each bar consecutively to (99-2-3), (179-54-5), (179-165-5), (46-179-5), (5-140-179),(79-5-179), and (179-5-169). Step 4 Insert Rectangle object and cover all area of project dimension. Step 5 Set the color of the Rectangle object to Linear Gradient as shown below: Step 6 Insert Bubble Layer object to the scene Step 7 Set the bubble's properties as shown below Step 8 Insert Lights Soft layer object to the scene as shown below Step 9 Set the Lights Soft effect properties as shown below: Step 10 Congartulation! You have just made a simple animation of spotlight effect.
