Posted on November 13th, 2012
2983 views Adding an effect to your flash logo will help it looks more live. Today we will present a tutorial about how toadd a Blur effect into a logo presentation.
Step 1 Download and Run IncrediFlash Xtreme 4.0 from here Step 2 Under Startup window choose Blank project and set the dimension to 400 x 300 pixels. Step 3 Set the Backgound to Stylish tile with Pipes type as shown below Step 4 Insert a rectangle object that covers the area of preview window. Set the Fill Color to Solid and alpha to70 as shown below.
Step 5 Insert text object that sounds "Top 5 novels of all time (voted by regular people)" as shown below Under its Apperances tab window add Blur effect filter as shown below
Step 6 Insert text object that sounds "To Kill a Mockingbird (by Harper Lee)" as shown below Apply "Pan/Zoom?Rotate" effect to the object as shown below Under its Apperances tab window add Blur effect filter as shown below
Step 7 Insert text object that sounds "1984 (by George Orwell)" as shown below Apply "Pan/Zoom?Rotate" effect to the object as shown below Under its Apperances tab window add Blur effect filter as shown below
Step 8 Insert text object that sounds "Pride and Prejudice (by Jane Austen)" as shown below Apply "Pan/Zoom?Rotate" effect to the object as shown below Under its Apperances tab window add Blur effect filter as shown below
Step 9 Insert text object that sounds "The Lord of the Rings (by J.R.R. Tolkien)" as shown below Apply "Pan/Zoom?Rotate" effect to the object as shown below Under its Apperances tab window add Blur effect filter as shown below
Step 10 Insert text object that sounds "The Catcher in the Rye (by J.D. Salinger)" as shown below Apply "Pan/Zoom?Rotate" effect to the object as shown below Under its Apperances tab window add Blur effect filter as shown below
Step 11 Congratulation! You have just made a flash effect animation of a logo. |
