How to Recover WAV Audio Files on Mac
Posted on November 2nd, 2012
Mac OS X
Question about WAV Audio Recovery
"I have a WAV file upon Edirol R44, and the file isapparently corrupted. The file size is all about 240MB nonetheless itdoes not show running time when I open the data. The data seems to bethere nevertheless it only opens on VLC. Is there any software that Ican recover the WAV file for Mac, preferably?"
.WAV File Extension
Standard digital audio file format used for storing waveformdata; allows audio recordings to get saved with assorted sampling ratesand bitrates; often saved in a 44.1 KHz, 16-bit, stereo format, which isthe standard format used by CD audio.
WAV is short for "Waveform Audio File Format," and ispronounced "wave." WAV files are like .AIF files, but they are based onthe Resource Interchange File Format (RIFF), instead of the AudioInterchange File Format (AIFF). WAV files are generally seen onWindows-based computers, while AIF files will be more common onMacintosh systems.
Recover iTunes WAV Audio Files
In the world of computers, Data Recovery software is one thing we all know and depend on to recover lost of missing data.The process of file recovery is very complicated, the one which youshould never try and do yourself. Hard drives especially, are veryfragile and require extra special care when they are worked on. You haveto be careful using the small components inside of them, and that's whyonly a trained specialist needs to be attempting data recovery.
Whenever something happens to your hard drive and you alsolose your data, it is wise to leave it to the data recovery experts.Companies who specialize in data recovery can recover crucial computerdata, and get it done the right way - which could save you time andexpense in the long run.
Well, if you have had the same problem as the users mentionedat the very beginning, how do you fix it successfully? Here with thistutorial you will know the efficient method to recover WAV audio files on Mac.
1. Go to google.com to search professional audio recovery software, such as uMacsoft Data recovery is my recommendation.
2. When installation and launches recovery program, youshould let the software scan your hard drive to search lost or damagedWAV audio files completely.
3. When finishing scanning task, you will get your audiofiles listed on the interface of application. In addition, other typesof files or data are also can be recovered meanwhile, if you like, youare able to preview them; there is "Recovery" button allows you to getthe lost files back perfectly.
Mac Data Recovery
Note and Tips
You cannot recover the files to the same drive where theywere lost, therefore choose another volume or some external storagedevice such as a USB flash drive to save them safely.
In order to avoid repeating recovery job to find your gonefiles, you'd better mark your important files as read-only, or makecopies of them periodically.
