Posted on January 10th, 2013
3952 views Description: the SD card has the Pro of small volume, fast transmission, easy to carry and so on. But the Cons are card losing, cannot be reading by computer, data loss and so on, then, you can perform SD card data recovery to undelete your SD card.
SD Card, the full name Secure Digital Memory Card, was developed by Panasonic, Toshiba, and SanDisk on August, 1999. The SD cards, as non-volatile memory card format, are widely used in portable devices such as: Digital Camera for storing photos and videos Camera VCR for photos and videos Personal Digital Assistant for all kind of data Multi-Media Player Mobile Phone for photos, ringtones, songs, videos and so on GPS navigation devices Tablet computers
As a convenient data storage tool, the SD card has the Pro of small volume, fast transmission, easy to carry and so on. But the Cons are card losing, cannot be reading by computer, data loss and so on. Usually, the data lose from you SD card is because of:
When you lose your important files from SD memory card and want to recover your them from your SD card, the first thing you can do is stop input any data into your SD card, because the new data input will overwritten your SD card so you cannot find them back even with a SD card Data Recovery Tool. Recover your delete/format/lost files from SD card with Odboso File Retrieval step by steps Odboso File Retrieval photos, videos, audios, zip files, documents, emails, html files from your SD card. 1. Download SD Card Data Recovery tool and install it in your computer; 2. Connect your SD card to your computer with a card reader or SD card port, you will find your SD card in My Computer as Removable Disk; 3. Run SD card data recovery tool, choose your removable disk and scan it! 4.Select the file formats you need to recover and click "start scan" button, for example, you need to recover your deleted document files from your SD card, just select document. 5.Preview your lost files after scanning your SD memory Card, you may find files you deleted or formatted even 2 years ago, just select the files you need, click the recover the recover button to recover your lost files from SD card! Tips for you to protect your SD card from data losing Backup your SD card timely for restore,
