RSS/Atom feed Twitter
Tutorial: The creepy zombie hand of death!
Written by , translated by devvv · Created on Dec 18, 2009, last updated over 13 years ago CC BY-NC License
Motivation
In this tutorial I show you how to transform your own hand into a creepy zombie hand of death that is full of blood! I love to think about such cool looking titles ;) Enjoy the tutorial!
Tutorial details
  1. 1
    Make a photo of your own hand against a single colored baclground. Crank your hand and be sure that all single fingers are well viewable not overlapped.
  2. 2
    Scale the Foto to app. 1000px height. Mask your hand. You can use the paths tool very good for this. Click aside your hand – the advantage of the paths tool in this specific case is that you can use curves for some parts of the fingers. You can save alot of clicking when using curves.
    Don’t forget about the in-between areas.
  3. 3
    So far, so good. We’ve now got a hand on a transparent background. Create a new layer and fill it with any dark gray.
  4. 4
    Now we’re desaturating the hand using the channel mixer.
    - Go to Colors / Components / Channel Mixer.
    - Set to “monochrome” at the bottom of the dialog.
    Choose the values from below. The aim of this step is to get a nice contrast in the end. But make sure you don’t create too much plain white or plain black.
  5. 5
    NExt we’re transforming the hand a little bit to look more zombie-like. We’re squeezing the single elements of your fingers.
    (optional: if you have masked the hand using a layer mask like me, please click right on the layer in the layers dialog and choose “Apply layer mask”.)
    - Filter / Distorts / IWarp
    Set the deformation radius to 40 und the deformation to 0,3. The plan is to squeeze the fingers (especially the phalanx). Work in the IWarp preview window and move the fingers together from outside. It is legitime that it may look a bit unnatural.
  6. 6
    The hand should look like this now:
  7. 7
    We make it look a little more creepy by emphasize the crinkles:
    - Filter / Enhance / Unsharp mask: Choose 10 / 0.75 / 0 as values.
  8. 8
    Now darken the already dark parts of the hand a bit.
    i.e. use Colors / Levels to do it like shown in the picture below. Set the mid tones to 0.85
  9. 9
    Next we get rid of the thumb. Use the free selection tool and cut it as shown on the picture:
  10. 10
    Download the meat photo (on the top of the tutorial) and load it into the image using File / Open as layers. I’ve chosen a nice part of the meat that I want to use to join the cut part of the thumb.
    - right click the layer in the layers dialog: “Add Alpha channel”.
    - Colors / Desaturate / Luminosity
  11. 11
    Take your time to find a nice part! I tried it some times too to find a suitable one! Now cut out the part of the meat.
    Darken it using Colors / Curves (move the curve down a bit) so that it looks more like the gray tone of the hand.
  12. 12
    I rotated it a bit and used the rfee selection tool to make it a little more uneven (i cut out some small parts).
  13. 13
    Now merge the flesh with the hand layer. Use a right mouse click on the flesh layer in the layers menu: “Merge Down”.
    Now use the Dodge/Burn-tool to darken some parts that do not fit the correct gray tones. Please set the tool to only 30% opacity and use a smooth brush. Also cut some holes into the flesh to look more realistic. I used the eraser tool to make the little holes. Darken the area around the holes using the burn/dodge tool.
  14. 14
    Now we’re getting to the colorize part. It is important to get two sligtly different colors into the image because it will look cooler then. Our aim is to use 2 duplicated layers of the hand and add different layer masks to them. One mask will focus on the bright parts another on the dark parts of the hand.
    - Duplicate the hand layer 2 times.
  15. 15
    Open the channels dialog. The bright parts of the image are found alsmost in the red channel of the image. Right click the red channel and choose “Selection from Alpha”. Make sure that all of the channels are still active and selected, not that you misleadingly deselected one of them.
  16. 16
    Change back to the layers dialog. Click and activate the top layer duplicate. Add a layer mask to it and in the pop up dialog choose “Selection”.
    Change to the layer below, add a mask too. This time use selection too, but don’t forget to choose the “invert mask” option on the bottom of the dialog. This will invert the mask after clicking ok.
    Stay on the layer mask and choose Colors / Brightness&Contrast. Set Contrast to +50.
    Do the same for the other layer mask you just created on the other layer.
  17. 17
    Choose the layer where the bright parts are selected. Now use Colors / Colorize: 90 / 50 / 0 to get a green tone. Switch to the other layer and repeat Colorize using these values: 205 / 30 / 0. This will give the dark parts a colder, more blueish tone.
  18. 18
    We’re getting to the end of the tutorial.
    Now we need some blood.
    - create a new transparent layer.
    - choose the brush tool. use the sparks brush and use the jitter-option. Set it to 3 and scale the brush to 2.5. Paint some chaos on that new layer.
  19. 19
    - Colors / Curves. Move the points together as seen on the picture.
  20. 20
    Go to Colors / Colorize again: 0 / 100 / -75. Set the layer mode to “Soft light” afterwards.
  21. 21
    Get rid of the blood that is outside the hand now. Choose “Selection from Alpha” from any hand layer to get the selection. Use Select / Invert or Press CTRL+I and press DEL to delete the selected parts.
  22. 22
    Download the background, that I prepared. Open it using File / Open as layer. Scale it to the right size and put it to the back of all layers.
    If you want to learn how to make such a nice grunge background have a look at the “Architectural Dream Wallpaper” tutorial on our site.
    The original idea to to tutorial came when playing Left 4 Dead and looking and when looking at the cover of a DVD. I hope you had lot of fun with the tutorial and enjoyed it.
Comments
Subscription management
User rating
This topic (The creepy zombie hand of death!) has been rated 5.0/5.0.
Mynor
about 8 years ago
This is a great tutorial!
A lot of effort in creating it. Kudos to the author!
Pavel Espinal
over 8 years ago
If you follow everything until step 3 in GIMP 2.8, you don't end having a gray hand over a transparent background, as shown in picture. This is not accurate.
Mostly, you will end with a full color hand with a transparent background.
Either you correct the picture or you put the missing steps. This is misleading.
Shadowarr
about 9 years ago
PLS ANSWER!
Shadowarr
about 9 years ago
At step "17" it says that "colorize is able only for RGB layers and I can't colorize! Help!
over 9 years ago
which step are you working on?
Pedro
over 9 years ago
when i add the new layer my hand isnt grey help pls i want to get this done
zuse
almost 10 years ago
doesn't work. Some more steps for bloody beginners, please.
(can't desaturate the hand, only the background...?)
over 10 years ago
thanks for mentioning, unhammer... there are 6 more images that are the results of my tutorials... thats cheek! I will contact the seller. thanks again!
unhammer member for over 14 years unhammer 25 comments rated this topic with 5/5
over 10 years ago
thought I should let you know this
http://www.ebay.com.au/itm/Photo-Image-Editing-for-Adobe-Photoshop-CS-6-7-8-10-11-Elements-Full-Retail-user-/141063615708?hash=item20d80bf4dc is using your CC-BY-NC images commercially and without attribution.
richardrachael member for over 13 years richardrachael 1 comment rated this topic with 5/5
over 13 years ago
OK I think I missed something what do you set the different layers of the hands to?
rober garcia
over 13 years ago
vey very well
over 13 years ago
After clicking the points of the path you need to hold CTRL on your keyboard and click the first path point to get a connected area. After that press ENTER to get a selection from the path. Now you add a layer mask (right click the layer in the layers dialogue and choose "Add Layer Mask"). With the active selection choose "From selection" in the pop-up-dialogue. Then your hand should be on transparent background and you can continue making the tutorial.
I hope that helps ;)
dragonassbabe
over 13 years ago
around the paths and masking near the top i had to quit , skipped a step, so i dont know what you are doing. too bad wanted to do this one.
K4dmon rated this topic with 5/5
about 14 years ago
The image looks great, and most of the explaination is good. But I couldn't make the pathts in the masks work. So I have an image with the background inside the hand as well...but that looks cool also, I just can't see the details now. I will rate this with 5 stars because i'm a newbeginner
diego rated this topic with 5/5
about 14 years ago
woooooowwwwww excellent!!!!! thank you very much
The Internet rated this topic with 5/5
about 14 years ago
very nice
Tim
over 14 years ago
Cool tutorial, but how did you get that single window mode?
Ramon Miranda
over 14 years ago
Awesome tutorial. good results and well explained. i dont like zombies but can aply this to other things too. so thums up.
