Well i have this header in flash but i dont know how to edit the text.
thats the banner but none of the options on the left side are aviable please sommeody help
Text Help!
Started by
TMZHosting LLC
, Oct 02 2005 04:53 PM
8 replies to this topic
Posted 02 October 2005 - 04:53 PM
Posted 02 October 2005 - 04:57 PM
you have to make the text in flash for it to be editable.
Posted 02 October 2005 - 04:59 PM
how do i do that lol this is my first time using flash and i have no clue what to do since i didnt make that banner. i downloaded that one well it actually came with the skin i downloaded but i cant edit it.
Posted 02 October 2005 - 05:08 PM
you have to open the .fla file, otherwise you cant edit it, then you click the little A to make text..
Posted 02 October 2005 - 05:18 PM
how can i save a file as .swf when i try to save soethign it only says i can save in flash
i need to save it as swf how can i do that
#6
Posted 02 October 2005 - 05:20 PM
you goto File > Export and it will save as .swf.
#7
Posted 02 October 2005 - 05:24 PM
when i go to file i dont see export i only see inport
#9
Posted 02 October 2005 - 11:28 PM
Or you can just play the movie by pressing Ctrl+Enter and it creates the swf file
