Best way to manage Flash blog entries?
Posted 22 January 2007 - 10:22 AM
Are there any decent tutorials to load text files onClick into a text field (XML)? Would that be the best method to keep filesize down?
Posted 22 January 2007 - 11:32 AM
Take your time building it, be patient, and do it right. Its difficult, I know...I'm struggling with the website im making right now, I want to toss it online before its done...but Im waiting until I have some content in it and the design locked down.
If you make a good solid website, youll be proud of it in the end. Might take twice as long, but more often or not, its worth the feeling...at least it is IMO.
Posted 22 January 2007 - 07:53 PM
Posted 22 January 2007 - 11:17 PM
The problem with that, however, is that when you go to a random blog in my archive, you have the option of clicking on "previous blog" or "next blog", and I'd have no idea how to set up multiple text file browsing using only one scene , or possibly one text file with multiple variables...but remember I would only have 2 buttons at the most for navigating through the entries.
Posted 22 January 2007 - 11:33 PM
Edited by d4rkst0n3, 22 January 2007 - 11:33 PM.
#6
Posted 23 January 2007 - 03:01 AM
I have nothing against loading XML's I do that all the time, as long as it's suitable for me.. But for such a project like a blog or even a big sized photogallery.. no thanks.. I moved over to AMFPHP
In your situation I would also move over to AMFPHP, there is good site from a contributor of AMFPHP called
http://www.sephiroth.it
It takes a little while to understand it, but as soon as you got it.. It's a wonderful thing
#7
Posted 23 January 2007 - 09:11 AM
To get my stuff working I took the defualt files that AMFPHP came with for the examples and just added my own stuff, and changed what was there until it suited my needs. This way I always had the layout and whatnot correct. It helps loads the first couple times you go to set it up.
Just post here if you have any trouble.
Edit:
On the flip side, we have a project at work that is for Daimler-Chrysler (in use as a pilot at the auto shows in Canada this year, and the US next year) that runs off gigabytes of dynamically generated xml. And it is an UGLY beast...but it works. We started this well before AMFPHP was useable tho. It never loads all of the xml at once, only smaller bits get sent to it at a time. We saved out a copy of the xml generated by Java and tried to open it, and there was no program that could, due to the huge filesize. We had to develop a program that would open sections of it to prevent our computers from crashing.
Re-Edit:
Just talked to the developer on the XML project today, the majority of the content has been re-done to use openAMF (port of AMFPHP for Java) rather than using so much XML. The database that we had the huge ammounts of xml files from will only be getting bigger, so to streamline, we're using AMF.
Edited by Pax, 23 January 2007 - 02:11 PM.
#8
Posted 23 January 2007 - 12:45 PM
Wow Pax, that does sound like a nightmare. Gigabytes of XML?! Sheesh. Sounds pretty terrible just figuring out why the computers kept crashing and setting everything up.
#9
Posted 23 January 2007 - 02:16 PM
#10
A few megs of xml in one file will probably make your computer crash At least notepad or whatever you open it in. An entire database was converted into XML, which is why it was so large. Sounds like the idea was to use it for debug purposes, but the developer didnt realize how large the file would be when all the data was in one file. Usually it uses a number of smaller xml files that are either static, or generated as required. But like I said in my edited post, thats been changed to use AMF now. Its just faster when you have lots of data. Although, XML is AS3 will be much quicker, opening up some more doors. I've also heard of JSON (JavaScript Object Notation) is about as quick as AMF, but Ive never used it.
#11
Posted 23 January 2007 - 03:48 PM
Other solutions would be Flex or Flash Remoting
#12
Posted 23 January 2007 - 08:13 PM
#13
Posted 23 January 2007 - 09:06 PM
I agree with everyone here, but XML is still good to learn. You can just type your data straight into it and load it into Flash. But I'm going to have a look at AMFPHP see how good it is
It's not that I don't know how to work with XML or anything, I do. But the thought of having to setup multiple dynamic text fields for each individual archive entry is too much of a hassle for it's worth. That and I can't figure out a way to load different txt files into the same dynamic field with the click of a button and i'm pretty sure it isn't possible.
#14
Posted 24 January 2007 - 04:05 AM
#15
Posted 24 January 2007 - 08:43 AM
