Darts Modeling - Create real looking darts in 3d studio max with simple techniques
Posted on July 7th, 2011
3D Studio Max
Real looking darts tutorial:
Intro: In this tutorial, i will teach you some basic and simple techniques to make real looking objects!
Final
Modeling DART TIP:
Step 1: Creating cylinder:
Create a cylinder in (Left viewport) (Create panel > Geometry > Standard Primitives > Cylinder) with the following parameters:
  • Radius: 1.0
  • Height: 30.0
  • Height Segments: 10
  • Cap Segment: 1
  • Sides: 20
 Dart tutorial img 01
Step 2: Applying modifier:
Now apply (Taper) modifier from (Modifiers> Parametric Deformers> Taper)___ with the following parameters:
  • Amount: -3.0
  • Turn on limit effect
  • Upper limit: 10
Then click on the PLUS sign on the taper option as shown in the figure and select (Center) and position it with the help of gizmo as shown in the figure:
 Dart tutorial img 02
Creating DART BARREL:
Step 3: Creating cylinder:
Now create another cylinder in the (Left viewport) (Create panel > Geometry > Standard Primitives > Cylinder) with the following parameters:
  • Radius: 3.7
  • Height: 45.0
  • Height Segment: 10
  • Sides: 20
 Dart tutorial img 03
Step 4: Applying modifier:
Now again add the taper modifier (Modifiers> Parametric Deformers> Taper) with the following parameters:
  • Amount: -3
  • Upper limit: 41
And again by going in the taper drop down list select (Center) and set as shown in the figure:
 Darts Img 04
Step 5: Creating spring for the grooves:
Now create a spring (Create panel > Geometry > Dynamic Objects > Spring) with the following parameters:
  • Height: 31
  • Diameter: 7.8
  • Turns: 18
  • Segs/turns: 100
  • Select rectangular wire
  • Width: 0.7
  • Depth: 0.9
 Darts Img 05
Step 6: Applying BOOLEAN operation:
Now select (ProBoolean) (Create panel > Geometry > Compound Objects > ProBoolean) if you are using 3D Studio Max 09, 2010 or 2011! Or if you are using any lower version of 3D Studio Max then select (Boolean) (Create panel > Geometry > Compound Objects > Boolean)  , while cylinder 02 is selected. Now click (Start Picking) and subtract spring from Cylinder 02. As shown in figure:
 Darts Img 06
Darts Img 07
Creating SHAFT:
Step 7: Creating shape of SHAFT by using Splines:
Now it's time to create the SHAFT of a dart, select (Line) (Create panel > Shapes > Line) and create a shape in (Front view) as shown in the below figure:
 Darts Img 08
Step 8: Applying modifier:
After creating a shape like that, apply (Lathe) (Modify > Modifier List > Lathe) or (Modifiers > Patch/Spline editing > Lathe) modifier from the drop down list, with the following parameters:
  • Segments: 30
Everything else remains the same. Now click on the plus sign made on Lathe modifier, and select (Axis) as shown in the following figure, now drag the "Y" axis with gizmo in the front viewport, until you get the image like mine.
Darts Img 09
Creating FLIGHT of a dart:
Step 9: Creating FLIGHT by using spline:
It is the last part of dart modeling. To make dart FLIGHT, first create a line in the (Top viewport) (Create panel > Shapes > Line) and draw a shape like shown in the figure below:
 Darts Img 10
Step 10: Applying modifier:
After creating a shape like that, apply (Extrude) (Modify > Modifier List > Extrude) or (Modifiers > Mesh editing > Extrude) and give it little thickness.
After adding the extrude modifier, clone it by pressing shift key and dragging the shape, then rotate and position it as shown in the figure:
 Darts Img 11
Next Page
Pages: 1 2
Shaiz
