Posted on July 16th, 2012
1480 views Do you want to make any slides with any background (template) and any transition? There is an easy software now, just add some slides, than change the background and transition. We will show you how to do it easily.
Step 1 Download and Run Flash Incrediflash XTreme from here Step 2 From startup menu, choose "Blank Project" & click on "OK" button. Incrediflash XTreme will show a window to choose the dimension of the project. We choose "Custom" and we use 400x300. Step 3 For this lesson, We use "gradient" and "stylish" for the background. Step 4 We will show you how to make a different scene transition.Before we add a scene transition, we need to enable Overlap scene transition setting within Movie Tab. By default, a newproject will have this setting disabled. When it is disabled, the next slide transition effect will play as soon as thecurrent slide terminates without any overlapping period. This is not good for a project such as photo slideshow where youwant the transition effect to overlap. To enable this setting, simply go to Move Tab and check Overlap Scene Transition. When this setting is enabled and you have chosen a transition effect for current scene, you will see the Timeline Windowis showing an overlapping duration (area colored in yellow). Do this step for other scenes. Step 5 You can add some objects too, like add text, image, shape, etc. We add some objects here. Step 6 Congratulation! Your random transition effect is done. Here is the result:
